Pontiac Grand Prix GTP
8 von kappa    zurück
weitere Bilder
ZZP spark plug wires 10.5mm
- Throttle body spacer
- Kältere Kerzen (NGK TR55 iX Iridium)
- Thermostat (82C) - 3.4“ Superchargerpulley
- Throttlebody heatshield - Shorter billet dogbones
- ZZP Billet Fuel Logs - Alu transmission pan
- Front and rear powerlog (Krümmer) - 5.5" underdrive Waterpumppulley
- ZZP Poly dog bone bushings - ZZP 3800 1.0 PCM
- INTENSE Polyurethane Upper Motor Mounts - Cherry bomb Resonator
- ZZP 3” Downpipe with Magnaflow race Kat - Flowmaster Endtöpfe
- ZZP High Velocity Throttlebody - 2,5” Exhaust
- ZZP 3800 High Voltage Coil Packs - Billet thermostat housing
- Ceramic Coated Crossover Pipe - ZZP Billet Fuel Logs
- Ported and Machined lower intake - GPO Grill mit Alu inserts
Verschiedenes: - Spyder headlights + LED taillights
- Front swaybar link mit Polyurethan endlinks - Aeroforceuhr (liest Daten aus Computer)
- 2004 Armaturennadeln - Steel brake lines
- Rear sway bar - LED Innenbeleuchtung - Roofrails from a 40th Edition GP - HPS Tieferlegung 3cm
- Strut tower braces vorne und hinten - Rebuilt M90 Snout
- Chrome moly trailing arms Polylinks - Rebuild 4T65E Transmission to HD:
- ZZP 3800 Billet Thermostat Housing Gemini Chain set
Input shaft up to 600hp
Oil pump shaft
ZZP Heavy duty flexplate
HD Diff cover
HD Final drive differential
Baujahr: 2000
Eingestellt: 23.06.2024 - 10:39
Weitere Pontiac Grand Prix GTP von Mitgliedern:
1978 Pontiac GrandPrix 1982 Pontiac Grand Le Mans 1988 Pontiac Grand Prix Coupe 1964 Pontiac Grand Prix 1979 Pontiac Grand Prix sj 1975 Pontiac Grand Am
